Want power from f350
Well it's a 6.0 powerstroke everything is stock except for the intake
it's a 6.0 power stroke stock except for the intake
Last edited by Krizacosta915; Aug 13, 2013 at 11:52 PM. Reason: Automerged Doublepost
The head bolts on the 6.0 are know to stretch which result in the head gaskets leaking if your looking to start adding horsepower you will eventually blow the gaskets the fix is to install arp head bolts they don't stretch out like the factory bolts to add easy horsepower with out worrying about the heads is to do a cold air intake and 4 or 5 inch turbo back exhaust you should gain around 30 hp
Thank u for the info
Ok so so far I already order the arp head studs and a egr delete kit .. I'm holding up on the tunes since I don't have the codes and ima take care of the exhaust this weekend what else do you guys recommend
Last edited by Krizacosta915; Aug 15, 2013 at 10:58 PM. Reason: Automerged Doublepost
