5.9 Wont Start
Old Aug 13, 2013 | 07:12 AM
brandon22's Avatar
Default 5.9 Wont Start
My turbo went out on my 2003 5.9 Cummins. Removed turbo after pulling it to garage. My truck turns over but will now not even start. Any suggestions?
Old Aug 19, 2013 | 06:32 PM
Blavoie1990's Avatar
unplug any wires and forget to plug in? loose prime in fuel system? check your fuses to
Old Aug 24, 2013 | 09:41 AM
vkaercher's Avatar
I have the same trouble with my 5.9. I changed the injector solenoid and wont start. Ive tried bleeding the fuel system (which your not supposed to do on these trucks), traced down any electrical problems I could find but came up short, and checked the crank sensor. I'm kind of at a loss so I'm going to take it to a dealership on Monday. Ill let you know what they say.
Old Aug 24, 2013 | 12:14 PM
K80's Avatar
K80
Common Rail systems are self priming. Check that you have all connections plugged in. Remove battery connections for 10 minutes. Put them back on and start there.
Old Dec 1, 2013 | 07:55 AM
coxey2's Avatar
Default figure it out?
Mine did the same thing. Figure it out yet? thanks
Old Dec 2, 2013 | 02:18 PM
vkaercher's Avatar
I ended up taking it to the dealership and they replaced the pcm, primary and secondary fuel pumps, and 1 injector. They had it for two weeks and basically just threw parts at it.
ronstop
Feb 26, 2015 09:48 AM
Gatorm
8
Dec 23, 2014 11:53 AM
texasd
5.9L CR Performance
8
Dec 20, 2014 07:39 PM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
mpenny671
Oct 7, 2014 01:18 AM
