Tranny Fluid Pan dripping
Old Aug 12, 2013 | 10:13 PM
largemouth813's Avatar
Default Tranny Fluid Pan dripping
HEY YALL JUST BOUGHT A 2004 RAM 2500 CUMMINS 4X4 AND I NOTICED THE TRANNY FLUID PAN IS DRIPPING....ITS KIND OF LIKE A SWEATING TYPE THING BUT DRIPS ON THE GROUND.ITS NOT QUITE A LEAK YET BUT I WANNA FIX IT FAST. ANY IDEAS???
Old Aug 12, 2013 | 10:45 PM
RedChevy44's Avatar
Make sure your transmission pan it straight where the gasket sits on it, make sure none of the bolts are stripped out, and go to the dealer and buy a reuseable gasket. They are around $19 plus tax, and they are WAY better quality than the cork ones that come in the filter kits. If you have the money I would buy a mag-hytec or similar deep transmission pan. The extra capacity helps keep your transmission cool and the mating surface is 1/2ish (something like that) aluminum which seals better than a stamped steel stock pan.
Old Aug 14, 2013 | 08:40 AM
dangerous1965's Avatar
Clean it all real good "brake clean" then run it and look for the spot. Could be a pin hole in the case or even the dip stick tube. Get it hot first then search!
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
InheritedDiesel
Jun 3, 2015 09:39 PM
BCOWANWHEELS
Wanted To Buy (WTB) - Used
Jan 7, 2015 03:42 PM
smokee
Nov 7, 2014 07:40 PM
