dana 70??
Old Aug 12, 2013 | 03:35 PM
diesel life's Avatar
Default dana 70??
i have a 2001 ecsb 4x4 just wandering what rear end this truck has??? its an auto.. any help is great thanks guys i searched but didnt find anything
Old Aug 12, 2013 | 04:42 PM
dieseldude848's Avatar
Old Aug 13, 2013 | 05:48 PM
thanks dieseldude i thought thats what it was but wasnt for sure.. do you know if there is a stronger yoke i can swap to?? i keep blowing u-joints out about every 6 months. so i thought maybe i could swap like a 1480 series yoke and u-joint in and make that stronger, but cant find a 1480 yoke to fit a dana 70..
Old Aug 13, 2013 | 07:23 PM
I don't believe so. Is your truck lifted? If it is not there should be no reason as to why it keeps eating u joints. Make sure your getting a high quality greaseble joint.
Old Aug 13, 2013 | 09:31 PM
no im not lifted.. i have used spicer, napa u joints and they keep going out all are greasable. im gonna throw a set of traction bars on it to see if maybe its axle wrap doing it.. i was also told by someone that on these trucks the only way to go was a solid joint?? havent tried one yet but this is my 7th u joint ive gone through. thanks for the info i appreciate it
Old Aug 13, 2013 | 09:36 PM
Im not sure if this would cause them to go, but your driveshaft may be bent, and needs to be balanced, or bad pinion bearings?
Old Aug 14, 2013 | 03:28 PM
ok i had thought about the driveshaft but then it doesnt vibrate or anything like that.. hadnt thought about a pinion bearing i will check it out. thanks for the info
Old Aug 29, 2013 | 02:09 PM
WacoHotshoe's Avatar
Something wrong with the driveshaft or carrier bearing.
Old Aug 29, 2013 | 10:09 PM
4x4manonbroke's Avatar
or your over torquing the u straps and pinching the cap into the trunion of the universal joint its self .... 20 Lb ft is max .... it will hold beleive me .... use a EP rated grease like Power Punch or Mystic #3
also have your shaft(s) spun balanced by a good shop ..... yo umay not feel the vibration but your trans and your diff can get trashed by just a small amount of vibration .....
Old Aug 29, 2013 | 11:04 PM
ok thanks for the info, as for the driveshaft being out of balance i would think that as many u joints as i have been through it would have already trashed the tranny... im still on the stock tranny all 189,000 miles of it so far, have a built one sitting in the garage waiting for this one to emplode
woodsman27
May 23, 2015 10:16 AM
tractormandan
Wanted To Buy (WTB) - Used
May 9, 2015 08:44 AM
scrnnmssuck
For Sale
Mar 20, 2015 11:55 AM
KYLEBOY
Jan 18, 2015 06:36 PM
gyayo2012
Nov 15, 2014 08:11 PM
