6.0 problem please help!!
Old Aug 12, 2013 | 02:58 PM
starboykevin's Avatar
Default 6.0 problem please help!!
i have a 2007 f250 6.0 150,000 miles
just did egr delete
arp head studs
new heads.
i just went on road trip to sturgis and went threw 2 gallons of coolant each way.
its not blowing white smoke.
no coolant in oil.
And no leaks.
where is my coolant going??
Old Aug 12, 2013 | 09:08 PM
zdawg801's Avatar
My buddy ran into this sort of problem with his pathfinder. I know Nissan and non American but I have never traced the coolant system before and I know he found that coolant leaked into his transmission. Could have blown it as well but did not. I'd say start looking into routing the system couldn't be to hard with help of technician
Old Aug 12, 2013 | 11:09 PM
04-6.0hshouldagota7.3's Avatar
Where the new heads trued? Verified flat? I have got out of spec heads before thus causing a popped head gasket on new heads. Also check for the the little crusties left behind from coolant evaporating, not just the obvious wet area. Four gallons seems excessive but if the coolant system wasn't properly "burped" or "bled" it would cause a need to add coolant. Hope this helps good luck!
burndiesel
10
Feb 7, 2023 01:15 AM
Tylerbuckley
9
Sep 21, 2015 08:24 PM
ish1521
Aug 26, 2015 08:42 PM
scubasteve12
Mar 29, 2015 09:39 PM
njnick
Nov 17, 2014 01:13 PM
