98.5 - no start.
Old Aug 12, 2013 | 07:53 AM
fsmyth's Avatar
Default 98.5 - no start.
Posted this on oilburners, and thought someone here might have a clue.
Quote:
Originally Posted by fsmyth View Post
Me, too. New injector pump, cranks great cold. Homebrew pump system similar to
FASS (dual pumps in parallel, dual frame filters). Did NOT have this problem
before the VP44 died, tho.
Pumps off while cranking, max pressure while cranking - no difference.
Finally finished killing the starter Replacing it today.
One oddity - I hooked the pump relays back up to the ECM (the wire that
used to run the pump on the block, and now that hookup no longer runs
the pump after 1st crank (the 3-second thing), but does keep the pumps
running for about 10 seconds after the key is turned back OFF. WTF?
<als>
Replaced starter. Now turns over like it should. Now it will not crank at'all.
Got a scan tool.
First scan: 1388 (auto shutoff relay), 1689 (manuf. specific powertrain...)
Cleared codes.
Second scan: 1694 (no engine bus...), 1693 (communication w/ECM)
Previous to this, O'Reilly scanned it, found 0463 (fuel level sensor),
0336 (crank sensor), and 1693 (comms w/ECM). These codes did not
come back after clearing.
Fuel pumps still acting stupid ( 1/2 sec run at crank, then shut off,
do not come back on for 5-10 sec. like they should). They DO come on
for about 15 sec. AFTER THE KEY IS TURNED OFF and REMOVED.
What now? Any guesses?
<als>
__________________
'98.5 2500 - bone stock w/added fuel pump, filters, gauge, boost gauge.
Old Aug 18, 2013 | 05:05 PM
RAW's Avatar
RAW
RPM on the gauge while cranking?
Fuses and Relays?
Doesn't sound like a lift pump issue, more of a communication issue with the pump.
Old Aug 19, 2013 | 01:24 PM
jigabop's Avatar
try swapping the fuel system relay with a different relay under the hood and see if it makes any difference?
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
