Quadzilla Adrenaline Gauge Hook Ups
Old Apr 7, 2008 | 03:18 PM
DB Admin's Avatar
Banned
Default Quadzilla Adrenaline Gauge Hook Ups
Ok so im finishing the install of the quad ,
I had to go to advanced to get another brass fitting to hook up the transmission temperature I must of lost one of the pieces ?
Anyway i have the ats intake so i thoiught what the hell and i would hook up the boost reading on the quad , I cant find no wires or senders for this what am i doing wrong ?
Old Apr 7, 2008 | 03:28 PM
Shecom3's Avatar
Mine reads boost from???it does show on the gauge though
Old Apr 7, 2008 | 03:33 PM
DB Admin's Avatar
Banned
Does it read through the Map or Something ?
Hell maybe mine works
Old Apr 7, 2008 | 03:40 PM
DB Admin's Avatar
Banned
If it does read through the Map Where is it pulling its reading from , I know the boost bolt in the head reads different then an Air Horn connection , I think the head is more accurate So IF it reads via MAP where is it reading from ?
Old Apr 7, 2008 | 04:22 PM
Shecom3's Avatar
It could be the MAP or the connector to the engine that is normally capped off..am not sure,but I know the digital guage is very responsive and changes quickly.Mine has shown 42 PSI top so far.I had problems with my trans temp connecter also and had to get a short pipe nipple with a union to connect,it didn't work correctly at first but was only because I was too light on the tight and didn't have a good ground to it yet,removing and retightening the assembly cured it though
Old Apr 7, 2008 | 05:11 PM
Jazz's Avatar
I did the same thing!! Couldn't find any wires for the boost but it works. Must read through the map sensor plug. Take it for a drive and it should read boost, mine did. Why?
Old Apr 7, 2008 | 06:20 PM
Yes it reads the Boost from the MAP sensor.
Old Apr 7, 2008 | 06:43 PM
DB Admin's Avatar
Banned
Where does the MAP get its Reading ?
Old Apr 7, 2008 | 06:54 PM
Its an electrical reading. Thats why when u unplug the MAP connector your truck will smoke more. It tricks the computer .
Old Apr 7, 2008 | 07:04 PM
DB Admin's Avatar
Banned
where does it read from ?
