2005 ford 6.0 coolant out the cap
Old Aug 10, 2013 | 07:38 PM
Josh Chretien's Avatar
Default 2005 ford 6.0 coolant out the cap
I have a 2005 ford 6.0 there is coolant coming out my cap just a little bit sometimes, seems to be on hills. Truck stays cool, no over ect 201 and oil temps stays good and close. I have a egr delete, no head studs but gaskets have about 100, 000 km on them. I had a pressure test done, it passed with flying colours. I also had a combustion test done on my coolant system two times, nothing came up. Truck has been on the scanner the coolant sensor seems to be working good and there are no codes for the fan. I just put a new thermostat in and still have a bit of coolant coming out sometimes.???????
Old Aug 11, 2013 | 06:45 AM
DirtyDiesel613's Avatar
I know this is going to sound dumb but did you ever purchase the updated Coolant cap 16lbs and have the dealer either slap the new sticker on the degas bottle for the proper level "lower". You might have too much coolant in there or the cap is the old one that was recalled. As long as you know your system is good on head gaskets the only thing for over pressurizing the system would be what I pointed out above with those temps.
Old Aug 11, 2013 | 09:06 PM
yes i do have the new sticker and i have tryed 2 caps now so im not sure what to think ??
Old Aug 12, 2013 | 01:05 AM
Thats about as far as my expertise goes with this specific problem. Hopefull someone else chimes in with that backwoods DIY fix. Theres surprisingly a lot of those haha. Best of luck.
Old Aug 14, 2013 | 03:04 AM
thanks man anyone els have any ideas ?????????
Old Aug 14, 2013 | 06:00 AM
Adrenaline junkie's Avatar
Try letting it go without refilling till u get a little lower in bottle. . .just make sure u have some in there:-) what coolant are you using. . . 75 gallons a min needs to be quality coolant with anti foam properties. . I use only ford gold . .
Old Aug 16, 2013 | 12:25 AM
alright thanks guys im pretty sure my rad is plugged or i have a blow head gasket
Apr 16, 2015 05:39 AM
slowstroke
For Sale
Apr 1, 2015 11:35 AM
keith63
6.0L Performance
Mar 18, 2015 12:35 PM
Nov 4, 2014 01:30 PM
