s300
Old Aug 8, 2013 | 10:00 PM
84chummins's Avatar
Question s300
I have been looking at turbos and trying to decide on which one I would like to buy. I plan on running some 5x14 injectors, denny t stage 2 fuel pin, arp headstuds, and some power screw adjustments. Ive been looking at the s300 turbos and it seems like there are so many different sizes such as 62,64, and 66. I was wondering which size would be the best for me to run?
Old Aug 9, 2013 | 10:16 AM
cougar's Avatar
I'm running a 62mm with my 7X10s and is a little laggy, but great for towing. The 5X14s are only a little bigger so I would hesitate going bigger than a 64. But I think the 62 would work better for you if your not doing much more than light towing.
Old Aug 10, 2013 | 08:41 AM
84chummins's Avatar
is it easy to reroute your intake cause i noticed that turbo has got that bend thing in it?
Old Aug 10, 2013 | 08:48 PM
cougar's Avatar
If yours is inter-cool, it's easy. If it's not, you should inter-cool it. There are other turbos out there without the 90° outlet with similar characteristics you can use instead. Mine is a High Tech Turbo HTB2.
Old Aug 12, 2013 | 02:52 PM
jkidd's Avatar
63/65/14 will be a nice combo with a set of 5x.014
Old Aug 13, 2013 | 02:10 AM
JasonQuartermile's Avatar
x2 on the 62mm. Made 487rwhp on mine...that's all the hp you're getting out of a 12mm anyways.
