What Opti-Lube product should I use?
Old Aug 8, 2013 | 06:38 AM
Opti-lube's Avatar
FormerVendor
Default What Opti-Lube product should I use?
Which product should I choose ?
Opti-Lube XPD is our most popular product because of the superior balance of improvement and protection found in this blend. XPD was not only rated the number one additive for lubrication, it also has a limited anti-gel chemical, a cleaning chemical package, and a cetane boost additive.
Opti-Lube Winter Diesel Fuel Improver is suggested for extreme cold climates, where temperatures regularly fall below zero. This product also contains a cetane improver and provides excellent lubrication.
Opti-Lube Summer/Warm Climate Blend provides excellent lubrication, and does not contain anti-gelling protection or a cetane improver. To many customers lubrication is a priority with an improver and performance boost is not an issue. Because of the low treatment ratio (3000:1), this is our most economical product.
Opti-Lube Summer+ Blend addresses those customers who want all the benefits of the regular Summer Blend but also want a cetane additive for better performance. Summer+ Blend has the identical mix ratios of the regular Summer Blend so it to is very economical to use.
All four of our diesel fuel improvement blends clean injectors, improve water separation, prevent fuel system corrosion and improve fuel economy.
Sep 13, 2015 08:20 AM
Mar 2, 2015 05:10 PM
