No power til warm
O.k. I think I have my last problem taken care of but on to the next.
I have noticed that sometimes I will start the truck and it will idle just fine but when I put it in gear it will have no power til warm. My fuel pressure is between 10-13psi when its doing this, and when its running normally.
Sometimes when this happens I will read 0 boost and then it will kick in all at once and start to pull like mad. Today when it happened I was showing that the boost was fine but there was still no power until I got a mile or two down the road and everything seemed to normalize.
I am running Rotella T triple protection and an AFE filter. Just changed the oil before this started happening. I have no oil leaks to speak of.
Any ideas?
Any ideas?
you shouldn't be running a diesel hard on a cold motor anyway.
and how cold are we talking here?
it does take heat and pressure to spool a turbo, and diesel fuel burns better warm/hot than it does cold...
you can always check and clean your IAT sensor
When I say cold I just mean that it hasnt been fired in a while and the engine has been brought down below operating temp. I am in TN and its summertime so its 80-90 here. I used to drive DT466s at work everyday so Im not super new to driving diesels, just owning one.
I will try and clean the IAT today and see how that does.
i imagine your truck is an automatic? if so it is your torque converter. it just needs a little time to catch up from sitting. not sure why this happens maybe someone on here might know, but before i put my manual in my truck would do the same thing if i didn't let it run for 3 mins or so.
1ATony
1A Auto Parts
Jan 5, 2016 12:03 PM
1ATony
1A Auto Parts
Dec 7, 2015 01:09 PM
1ATony
1A Auto Parts
Oct 29, 2015 02:11 PM
May 10, 2015 10:57 PM
