Cruise Control
Old Apr 6, 2008 | 09:32 PM
93/250's Avatar
Default Cruise Control
Need help fixing my cruise, the vss is good, and i have power to the cruise fuse, but not the switch, vacuum is also good, i read on another post someone talking about a clock spring in the steering column that causes cruise control to fail, could you explain this clock spring please, how much it is, and if its a hard fix. Thanks, Brett.
Old Apr 6, 2008 | 10:53 PM
GO OVRIT's Avatar
Its not a hard fix, but it is in the $200 range depending on your dodge dealer. If you have a steering wheel(or harmonic balancer) puller, then it'll only take 20 min or so. Don't spin it before you install the new one because you could damage it.
Old Apr 7, 2008 | 02:42 AM
93/250's Avatar
$200 part, or $200 including labout if a dealer does it? thanks Go ovrit.
burndiesel
10
Feb 7, 2023 01:15 AM
JBearSVT
Jul 9, 2015 06:16 PM
jdnetx
Jul 2, 2015 07:38 AM
Oil Igniter
Nov 27, 2014 05:56 PM
Cliffordthe24v
Nov 6, 2014 12:19 PM
