92 1st gen steering problem
Old Jul 30, 2013 | 05:36 PM
Couchman92's Avatar
Default 92 1st gen steering problem
My 92 12v has a problem and I'm not sure exactly what it is. When I turn tr steering wheel to the left it shifts it into neutral it's a 4 speed auto someone let me know if they know what's going on I have not a clue
Old Jul 30, 2013 | 10:39 PM
RedChevy44's Avatar
Look inside your engine bay by the firewall where the steering column comes through. The linkage from your shift lever travels down the column and hooks to some more linkage headed down to your transmission. If nothing is obvious have a friend turn the steering wheel while you watch it.
Good Luck!
Old Jul 31, 2013 | 04:06 PM
cougar's Avatar
There are bushings in the column that support the steering shaft and the shift shaft that can fail. As RedChevy44 said, have some one turn the wheel while you watch. You'll see it flop around. Had a Ramcharger that would do that, it also wondered all over the road.
Old Jul 31, 2013 | 08:29 PM
Couchman92's Avatar
Good Luck!
Thanks for the advice ill try it out and see if we can't get her running straight again
burndiesel
10
Feb 7, 2023 01:15 AM
Cdog121
Nov 16, 2015 01:49 PM
Tory4
For Sale
Feb 1, 2015 08:33 PM
Irish_Alley
Nov 28, 2014 12:57 AM
sweetv8s10
Oct 7, 2014 09:47 PM
