Oil pressure issue 2005 F550
Old Jul 28, 2013 | 08:08 AM
Speedy393's Avatar
Default Oil pressure issue 2005 F550
Can you have a large enough HPOP leak that you will not have any LP oil pressure?
Oil will fill up filter housing in about 6 seconds but do not have any pressure register on manual gauge. Any suggestions?
Old Jul 28, 2013 | 11:03 AM
bobfbigman's Avatar
Yes it is very possible, especially if the STC fitting has failed. generally you will have a "hot no start" condition if you have a high pressure oil leak that is bad enough to cause low oil pressure. I would also check out the low pressure oil pump gears and the oil pressure regulator that sits just behind the balancer on the crank shaft.
Old Jul 28, 2013 | 09:12 PM
Speedy393's Avatar
Is there any other test to run on the HPOP besides the air test? I am going to do it today.
I pressured the HPOP up through the ICP port. I could not hear any leaks and system held pressure for 60 seconds, did not loose any pressure at all. Now where do I need to look?
Durtyd09
Nov 11, 2015 01:43 PM
jhprice
Mar 29, 2015 09:36 PM
powerstroke4178
Nov 27, 2014 02:35 PM
veggyoilkid
Nov 10, 2014 12:39 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
