I HAVE NO FRONT BRAKES
Old Jul 28, 2013 | 02:59 AM
fmx23's Avatar
Default I HAVE NO FRONT BRAKES
The brakes were so bad on one side that the caliper pistons pushed out so far and blew the seals and leaked brake fluid out of it. I was driving when the whole front brake system stopped working and i had to drive it about 15 miles with just the back brakes working only. So it has all new rotors, calipers,pads on both sides now. Then I started by bleeding the front only. Every time i pumped the brake pedal it would go down to the floor and it had some pressure but it would not come up quickly. it comes back up slowly. and when the truck is running there is absolutely no pressure in the brake pedal at all. And the front brakes are not engaging at all.
So what could be the problem
2000 dodge 2500 24valve diesel
bone stock
Old Jul 28, 2013 | 06:02 PM
BarryB's Avatar
Sounds like to me that you still are getting air in the lines. Possible its time for a Master cylinder also.
shingi
Off Roading
Sep 30, 2015 11:17 AM
carid
Diesel Bombers Sponsors
Aug 11, 2015 06:24 AM
thatdude38
May 9, 2015 12:21 PM
kryz9903
May 4, 2015 05:00 AM
