steering hiss 911
Old Jul 20, 2013 | 12:14 PM
s10driver85's Avatar
Default steering hiss 911
04 ram steering hisses when wheel is turned. goes away when brakes are applied, or wheel is pointed straight. i have done a system flush and added a filter to low pressure return. no results. then i changed the power steering pump and another flush. no results. flushed again and added lucas oil power steering fix. no results. now from what i read its either a hydroboost brakes needs replacing or my lines. can someone shed some light on this puzzling problem.
Old Jul 21, 2013 | 05:37 PM
deerslayer1's Avatar
forget which line but one of the lines has a restrictor in it.remove lines at hydro booster and see if there is a clear looking tube protruding from it.had to do one on my buddies 06 but think there on the 04 also.he had same issues with a hard brakepedal also.hope this helps
Old Jul 21, 2013 | 07:38 PM
cerberus60's Avatar
It is not a restrictor its usually a liner problem. The liner slips down and gets into an area where the fluid causes noise. There is an updated line available.
Old Jul 22, 2013 | 06:47 PM
from everything ive read said if it was a liner hiss would happen with straight wheel and go away with movement. also a known problem on 4th gen
Im putting a double reverse male fitting on and bypassing hydroboost a couple wheel to wheel locks should tell me if its the hydroboost going into bypass. i swear the sound is coming from the steering wheel if that makes sense?
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
sweetv8s10
Oct 7, 2014 09:47 PM
