6.5L TD problems
Old Jul 13, 2013 | 05:02 PM
KSH2335678's Avatar
Default 6.5L TD problems
I have a 95' Chevy 6.5 TD. Its kind of hard to start, I have to put my foot on the pedal a little and try and start it. I have to feather it till it will stay running and then its fine, but it has a miss. It smokes a lot when it is first started and until you drive it a ways then it will stop. It drives fine for a little then it will start missing. If you try to get on it a little when you pull out of while you're driving. It hesitates/breaks up and carries on. I'm thinking it might be the optical sensor or PCM that is throwing the timing off etc. Can anyone help me?
Old Jul 13, 2013 | 09:28 PM
racer55's Avatar
First thing is to make sure the lift pump is pumping when the engine is running-it is powered by the oil pressure switch in stock form and they fail quite often-AC Delco ONLY for OPS replacement.
Also google "OPS relay mod" for long term reliability.
Also check for trouble codes.
Google OBD1 paperclip code reading.
HardLuck
Jun 24, 2015 08:04 AM
InheritedDiesel
Apr 12, 2015 04:35 AM
HeavyChevy95
Jan 11, 2015 04:31 PM
LTreis702
Nov 2, 2014 10:46 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
