jpt
Old Jul 13, 2013 | 05:59 AM
jpt's Avatar
jpt
Default jpt
I have an 04 5.9 just had some tranny work done. (I overtightened the side band adjuster and put in a new strut)this was corrected by a dodge ase mech. with a new gov. pressure and sensor added. My? is the truck has 210,000 miles runs great has original AC ,service has been done at reg. intervals, my mech. says I will probably need a new tranny in 50,000 or so, @ 3,500.00 should I put the $ in a 6.7 or fix this one when it happens? I get 21-22 on the road ????
Old Jul 13, 2013 | 07:52 PM
Nick060200's Avatar
Getting a new truck is always gonna cost more any way you slice it. If you like your truck keep it. Hopefully a new trans will last you another 200k+ miles.
Old Jul 18, 2013 | 03:43 AM
jpt's Avatar
jpt
Default tranny??
I just had a strut and adjustment put in a 48re My ? is should the tranny shift sound hard into low gear?also had pressure solenoid and sensor installed.
Old Jul 23, 2013 | 06:25 PM
tREEDx's Avatar
If you mean it goes from 2nd to 1st with a loud clunk, its probably because your TV cable needs adjustment.
