Overnight Crank/No Start
Well my truck ran just as good as it always has...yesterday. Got up today to move my truck so I could mow under it and what do you know, crank but no start.
Any ideas?
Weird....Went outside after the above the post and it kicked right off like it always does. Now I'm not so sure what to think or whether I can trust it if I go anywhere.
Update: Got in my truck to go and get lunch a little while ago. It cranked like it should and ran for about 15 sec, and then just died in its tracks like they key had been cut off. So, now I'm back to square one with the crank/no start.
Any ideas?---AutoMerged DoublePost---
Last edited by dlrobert95; Jul 12, 2013 at 01:16 PM. Reason: Automerged Doublepost
I don't see it being the programmer because it's had that same one since '09, but I guess I can give it a shot.
Trucks also throwing a P2614 code.
Last edited by dlrobert95; Jul 12, 2013 at 11:27 PM. Reason: Automerged Doublepost
What's all done to the truck? Could be losing the fuel prime, oil prime, many different things. Try cycling the key on for 30seconds, off, back on 30sec, off again and repeat. Make sure you have plenty of fuel
Back from the forum grave
I'm thinking it's a failing sensor or wires chaffing in the harness going to the sensor because I've figured out that every time it won't start or dies, I can wiggle the wires on the sensor and it will start back up.
Found my problem. Cam sensor wires had bare spots rubbed in them that when touched together shut the engine off. I isolated the bare spots and taped them up so I should be good to go now! Thanks guys!
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
