new to the 6.5 and the site
Old Jul 10, 2013 | 08:29 PM
mgwilson86's Avatar
Default new to the 6.5 and the site
Hi, my name is matt and im new to the diesel world and the sight......but im loving it.
I just bought a 1994 chevy k3500 6.5L td crew cab dually 4x4 but this is my first personally owned diesel and I love it. its great for me and my family and all my toys. The only issue Im having right now is how to achieve max fuel mpg. the guy I bought it from said 18 round town and 15 towing. im averaging 12mpg unloaded...is that normal mpg for a stock truck? Only mods or changes that I am aware of are the pdm relocation, new ip replaced with in last couple years and the boost gauge mounted on the pillar. I had a 6.6 that if I drove it slightly hard (not ******* it) I got decent mpg 16.5 or so. could any one tell me what/how I need to do to achieve the best mpg I can. thanks guys.
Old Jul 11, 2013 | 11:35 AM
racer55's Avatar
Welcome
A light foot is all you can really do,make sure that the air filter is clean and drive it easy.
A 3500 tends to come with 4.10 gears so mileage is not something you can really strive for with a 7000 lb + truck.
Old Jul 11, 2013 | 02:46 PM
mgwilson86's Avatar
ok thanks. I wasn't sure if it was how I was driving or what the 6.6 was a work truck and I wasn't sure if my truck would respond the same way. thanks for the info
Old Jul 11, 2013 | 05:06 PM
willsaratoga's Avatar
They have come along way since 1994. You cant expect the old man to run like a 6.6 two diff worlds there.
Nice Truck though.
Old Jul 21, 2013 | 11:06 AM
jrsavoie's Avatar
I consistently averaged 18 mpg on my 1994 K3500 single rear wheeled truck with 5 speed NV4500 trans, 4" exhaust. Since I put the ladder rack on, I've lost about 2 mpg.
On a 94 you will want to switch to a GM 9197 and newer K-47 air filter box from a 6.5 diesel.
You will also want to do the dual lift pump relay upgrade.
The 4" exhaust is also a good way to go.
Old Jul 21, 2013 | 02:57 PM
SRR's Avatar
SRR
Welcome! I have the 2wd version of your truck and love it also. I seem to be getting slightly better MPG than you are. I recently went on a 620 mile round trip car rescue and with an empty car trailer used a 1/2 tank to go 310 miles. I was pleased to say the least. On the return trip I used 3/4 of a tank but I had a 5200 LB car on my trailer. You can't drive these 4.10 geared trucks 70-75 MPH and expect to get good MPG, not gonna happen. Since the towing speed here in Commiefornia is 55 MPH, I try to keep it around 55-60 MPH. Unless I see a hill coming then it ***** to the wall!
Also, don't forget to add a quart of 2 cycle oil to every fill up to lube that injection pump!
