DRW TO SUPER SINGLE HELP???
Old Jul 6, 2013 | 12:02 PM
jdepuy618's Avatar
Default DRW TO SUPER SINGLE HELP???
I want to go to a super single rear wheel, but I don't want it to look stupid like those conversions that have the single tucked way inside the dually fender. I want a rim and tire that will fill in the fender well pretty good. If possible on the tire, I would like to keep an E load rating because I occasionally tow a fifth wheel or small trailers. So my question is what rim and tire options do I have that will fill in the dually fender well and still look proportional. I also have the occasional street races with a buddy on the streets so I'm looking for a street tire not a mud tire. Thanks.
Old Jul 6, 2013 | 02:35 PM
BarryB's Avatar
From my understanding, when trying to use a super single, your options on wheels are what you see is what you get. You are asking about the super single you see on the semi trucks and trailers correct? Only thing I can suggest is, if you want it be stuck out further, your going to have to use a spacer to set the wheel out. Which in my opinion wouldn't be has strong. Thats my $.02 on it. maybe someone else can chime in that has more experience.
Old Jul 7, 2013 | 10:26 AM
jdepuy618's Avatar
Thanks for the reply BarryB. I guess my post was misleading but I understand how you took it. I don't mean the 22.5's or the 19.5's on semis. I just meant one big rear meat on each side in the rear. I know I want a street slick or even better a tires that is load e but still like 14" wide at least. I'm not sure if that kind of tire is even made but that's why I'm on here asking. I'm just looking for rim and tire options given my preferences. Pretty much I'm going for the look and functionality of a street drag truck.
Old Jul 7, 2013 | 06:25 PM
tiremann9669's Avatar
When you blow one of those singles your 5th wheel will be on it's side
Old Jul 9, 2013 | 11:01 PM
dango's Avatar
mazzi hulk wheels are the ridiculously wide. here is a link of a super single i found with these wheels. their 18x10. I've seen these exact wheels on a SRW and they are super wide with no wheel spacer.
single in place of double wheel - Dodge Cummins Diesel Forum
good luck
Mar 11, 2015 04:00 AM
