Electrical problems...
Old Jul 5, 2013 | 06:49 PM
Sh3nan1ganz's Avatar
Default Electrical problems...
Sup guys, I've got a 05 f350 that just started losing its mind on the way to work today.
The batteries were replaced last October. But the battery light has been coming on ( bright then dim) off and on for about 2 weeks.
It had a hard time starting but fired,
About halfway to work the radio cut off and the abs light came on
A few miles later the radio came on and abs light went back off
After that a combination of on/off between the abs light, guage lights, odometer, and all guages happened.
All while the engine ran completely normal. I got to work and parked, turned the truck off and now it just clicks when I try to start it.
I'm guessing alternator. My only guess
If you guys have any other guesses or back up my imperfect theory please let me know.
Thanks
Sent from my DROID RAZR HD using Tapatalk 2
Old Jul 5, 2013 | 07:30 PM
mysterync's Avatar
What's the battery voltage key off engine off and at idle?
Old Jul 5, 2013 | 07:47 PM
11.56. V key off. I'm waiting for our jump box to charge so I can start it. It just clicks when I try to start it.
I load tested the battery and the batteries are weak, still good though
Old Jul 5, 2013 | 08:35 PM
mysterync's Avatar
I'm guessing you used an electronic tester or a carbon pile. You need to jump it and get a running voltage before you can do much. Have you verified voltage at the starter with it under load?
Old Jul 5, 2013 | 08:45 PM
Yea we've got a battery load tester at work. And no I haven't. I'll do that.
Old Jul 5, 2013 | 09:34 PM
Starter has the same 11.6 v
Old Jul 5, 2013 | 11:15 PM
Got it started. 12.36 v on both batteries. Only 2 amps coming off the alternator.. I think its the alternator. Lol
Old Jul 6, 2013 | 12:09 AM
Got it on... and running... but that "new" alternator is smoking slightly..
Old Jul 6, 2013 | 08:44 AM
mysterync's Avatar
Glad you got it fixed. An alternator really isn't designed to recharge batteries, only maintain them. So when recharging 2 batteries that are weak they'll heat up. Likely the smoke is just typical burn off though and its unlikely you hurt the alternator. Our denso rep is very stern that running a alternator with batteries that are failing will shorten the life of the alternator, and recharging dead batteries can dramatically reduce the life of the alternator... but folks do it all the time
culp7
14
Jul 20, 2015 10:13 PM
coryfast
Jul 6, 2015 06:02 AM
J. Nick
Apr 24, 2015 01:13 PM
Ol Goat
Jan 22, 2015 02:16 AM
TNTPrime
Jan 5, 2015 06:13 PM
