2005 ford 6.0 egr delete but intake still wet ??????
Old Jul 3, 2013 | 08:29 PM
Josh Chretien's Avatar
Default 2005 ford 6.0 egr delete but intake still wet ??????
hey i have a 05 ford 6.0 i did the egr delete my self so i know its done right my cooler is welded and pressure tested before put it in but the intake is still wet this is 10000 km later not coolant had left the bottle and ideas ???
Old Jul 3, 2013 | 10:16 PM
bobfbigman's Avatar
is it just wet with oil? oil is common caused by the vent line from the drivers side valve cover to the intake before the turbo
Old Jul 4, 2013 | 12:19 AM
i guess its oil how would i check ? it dosent smell like coolant ?
Old Jul 4, 2013 | 05:33 AM
HeavyAssault's Avatar
Unless you completely cleaned the intake manifold it's left over residue. Oil from the CCV would need to go a long way to get to the manifold. It's possible I guess.
Old Jul 4, 2013 | 11:58 AM
bobfbigman's Avatar
you will always have oil from the Crank Case vent in the intake, remember the air is flowing fast through the whole system and every part of the system is coated in oil unless a ccv mod has been done. when you add exhaust soot to it that is when it gets really nasty in the intake, you wind up with a slimy crusty mess
Old Jul 4, 2013 | 04:44 PM
should it be save to drive like im not sure what is going on ....
Old Jul 4, 2013 | 10:37 PM
bobfbigman's Avatar
all 6.0 intakes are wet with oil, if you are not loosing coolant then don't worry about it.
willyam
Price Quote - Request A Price
May 19, 2015 10:20 AM
Apr 16, 2015 05:39 AM
keith63
6.0L Performance
Mar 18, 2015 12:35 PM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
