View Poll Results: Should i buy this 12 valve?
Yes buy it for 5 grand
33.33%
Yes, but only for 4 grand
0%
Only pay max of 3500...
66.67%
Stay awayyy....
0%
Voters: 3. You may not vote on this poll
Should I buy this 94' 12 Valve??! HELPP!!
Old Jul 1, 2013 | 10:45 AM
RPPaving's Avatar
ATTN Should I buy this 94' 12 Valve??! HELPP!!
Whats up everyone, a friend of a friend is selling his 94' 2500 12 valve 4x4 single cab long bed with 137,000, here is "word for word" what he texted me about the truck:
"the truck needs to be reprogrammed, thats all that needs to be done to it"
"its really low geared because of it"
"it needs the shift points reset, it just shifts at a high rpm, thats it"
"no mods, just straight pipe"
"1 stack hole in the bed, or tail pipe, your choice on which you want"
"tranny has never been rebuilt to his knowledge (auto)"
"doesnt leak any oil"
"comes with an extra set of 60% tread, 33" Yokohamas"
"no rust on the truck, it came from Missouri"
Ok first off....theres no computers on a 12 valve, so what is he talking about when he says the truck needs to be reprogrammed?? how would low gearing make it shift like that??
I think what hes "trying" to say is that the tranny is slipping and is gonna go soon...at least thats what I think
What should I look for when buying this truck: ask if the killer dowel pin has been replaced? where should i look for oil leaking...oil pan, anywhere else?
Is 94 a bad year for the 12 valve, I know its the 1st year for them and the interiors arent the "best" but are they different motor/tranny/suspension wise from the 95-98's??
Finally...he wants 5 grand for the truck, I said ill pay him 4, but if any of you offer input that makes me think its not that great of a deal, ill have to think about offering him 3500 then.
ANY input is greatly appreciated, I wanna join the Cummins club ASAP!!
Attached Thumbnails Should I buy this 94' 12 Valve??! HELPP!!-img_3771.jpg   Should I buy this 94' 12 Valve??! HELPP!!-img_8803-1-.jpg
Old Jul 1, 2013 | 05:18 PM
Red_Rattler's Avatar
High Tech Redneck
Ah yea no programing needed could be an out of adjustment tv cable. As long as its not all rotted out I'd start at 3500 and haggle from there as long as the rest of the truck checks out good. Same interior same suspension as all the others just a lower hp truck from the factory is all the difference. But that's easily fixed
Old Jul 1, 2013 | 05:55 PM
cummins Pride's Avatar
looks good but a bit ruff have no idea what he is talking bout programming on 12v but i would not go over 3500 at the max
Old Jul 1, 2013 | 07:08 PM
95taylor331's Avatar
Go drive it and romp on it a bit and see if the trans needs to be re worked, by romp on it I don't mean beat the **** out of it but load the tranny up since your skeptical, from the sounds of it I would start at 3500 and go no higher than 4000-4100
Old Jul 1, 2013 | 07:46 PM
olsmokey's Avatar
there most certainly is a "computer" on a 12 valve that could go bad and cause what he is saying is "low gearing"... its a funny little box with 3 plugs on the passengers side firewall called the pcm... they do go bad and if the right pin comes loose or corrodes you wont get overdrive or tc lockup which would make it low geared because you lost your cruising gear. when I lost the pcm in my 96 I could soak about 60 out of it on governer.
Old Jul 3, 2013 | 04:50 PM
i count that as a electrical switch not a computer
RA113024
Mar 13, 2016 07:42 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
TheBeattie
Dec 24, 2014 11:22 PM
woodsman27
Oct 26, 2014 02:13 AM
