Transmission build
Old Jul 1, 2013 | 09:39 AM
KingKC's Avatar
Default Transmission build
I burnt the 4th and OD clutches out of my 68rfe. I have it torn apart and I don't see any other problems. The truck only has 75k on it. I am going back with Alto Red Eagle, or Raybestos stage 1 clutches. Is there anything else besides the valve body that I should do while it is apart?
Old Jul 1, 2013 | 10:10 AM
NadirPoint's Avatar
What do you mean by "doing the valve body?"
Old Jul 1, 2013 | 10:18 AM
Install a shift kit
Luke
Old Jul 1, 2013 | 10:31 AM
KingKC's Avatar
As far as the valve body, I meant I am aware of the issues and that it needs to be checked. I haven't figured out how to list all my stuff yet but I am running an H&S black maxx with the overdrive tune, doesn't that negate a shift kit?
Old Jul 1, 2013 | 10:40 AM
NadirPoint's Avatar
I was not aware there were any HD Diesel-compatible 68RFE kits on the market at this time.
Old Jul 1, 2013 | 10:57 AM
shovelman's Avatar
You mean like this one??
http://www.ebay.com/itm/Dodge-Diesel-68RFE-Transgo-Reprogramming-Kit-2007-on-/281087428749?hash=item41721dc88d&vxp=mtr
Old Jul 1, 2013 | 11:02 AM
KingKC's Avatar
I knew they were available, but with my H&S overdrive tune should I still run a shifted kit?
Old Jul 1, 2013 | 11:07 AM
NadirPoint's Avatar
Well, that's eBay for ya!
I would refer to the Transgo site and ask them first. They say the 45RFE kit is upgraded to fit the 68RFE, but no mention of diesel anything.
NOTICE: This kit contains an electrical part (Resistor) which is not compatible with aftermarket engine programmers that modify the transmission hydraulic pressure.
I suppose it might be just fine. Let the buyer beware...
Old Jul 1, 2013 | 11:08 AM
shovelman's Avatar
All it does is makes the shifts firmer with less clutch slippage so I wouldn't see why not, but while the trans is apart you should probably install a good triple disk convertor (somebody can chime in on this with respect to the 68rfe) but I know its a weak link in 47/48 models
redveloce
Diesel Engine Conversions
38
Jan 22, 2017 03:55 PM
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
Trevlar11
Dec 11, 2014 03:30 PM
TheDirtyDozen
Oct 1, 2014 10:09 AM
