Running HOT at Idle
Old Jun 27, 2013 | 10:02 PM
Cumminnotstroking's Avatar
Default Running HOT at Idle
Over the past couple of weeks Ive started to notice that while at idle my truck seams to start running hot. Normal running temp is usually around 175-185 but at idle or while in traffic it reaches 210-220+ which also causes my trans temp to reach 220-230+, No good right. And then when I start to move again it goes back down to almost normal. After it happens once it doesn't take long for it to start again. Even while sitting at a red light it gets hot. Any Ideas anybody. Please help
P.S. Thinking about getting an intercooler, will this help at all ???????
Old Jun 27, 2013 | 10:55 PM
H.R.D's Avatar
I would drain and flush the radiator coolant and replace the thermostat. Also, do you ever hear you fan clutch kick in? May need to put a new fan clutch in it.
Old Jun 29, 2013 | 11:37 AM
Thanks HRD, I checked to see if the fan was coming on but didnt hear anything so i popped the hood to check an see if it was running. it looks to me like its belt drivin and constanly stays on all the time. i dont think it has a clutch. could be wrong though but none the less it is on and running. with that being said is there even a thermostate ?? anything else it could be ???
Old Jun 29, 2013 | 06:23 PM
H.R.D's Avatar
The fan will always spin but won't engage fully until a certain temp. You will hear it when it engages it makes a distinct sound.
This video kinda gives you an idea of the sound it should make.
realtrucksrattle
May 15, 2015 11:20 AM
Max713
Apr 17, 2015 01:18 AM
Dustin M
Mar 17, 2015 08:59 PM
jordanokc
Feb 8, 2015 03:59 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
