1998 dodge ram 24v losing prime
Old Jun 26, 2013 | 09:47 PM
Bob_22r's Avatar
Default 1998 dodge ram 24v losing prime
Hi all my second post in here! First one have been solved quick and easy! Hope this one will be the same! :p anyway if the truck is sitting for a couple of hour it won't restart unless I cycle the key a lot to prime the fuel system! Any idea of where to check first?
Also the converter won't lock it just try to lock half a second and unlock instantly and never seem to lock otherwise!!! Any thing to check? There's a lot of thread on the noise of the alternator but since he never seem to lock not sure if it is the trouble...
Old Jun 27, 2013 | 10:10 PM
Cumminnotstroking's Avatar
Im having the same problem with mine. Haven't figured it out yet. Somebody Please Help!!!!!!!!!!!!!!!!!
Old Sep 2, 2014 | 03:10 PM
GreenDieselF's Avatar
I would suspect a faulty check valve in the lift pump and your fuel is bleeding back. Not sure what to tell you on your trans, other than make sure your fluid level is ok and to try the noise isolator
Old Sep 3, 2014 | 04:24 AM
gh0stman's Avatar
Could have a small air leak in the fuel line.
Also I had the same problem as you have with the trans. I bought a BD noise filter to correct the issue. Once you get it connected to the vehicle get a can of battery terminal cleaner and a can of terminal sealer. Dont be stengy with either. Once you get them clean tighten the crap out of them on the battery. Use best judgement on the torque specs. Mine has gone away for now.
hoeky22
For Sale
Mar 15, 2015 08:35 PM
Dec 29, 2014 10:20 AM
Nov 24, 2014 08:20 AM
Nov 3, 2014 08:10 AM
Oct 24, 2014 02:50 PM
