73 International Travelette-Cummins-First diesel build
Old Jun 24, 2013 | 09:24 PM
Coal_Binder's Avatar
Default 73 International Travelette-Cummins-First diesel build
Well as posted this is my first diesel project. And first post at Diesel bombers at that. a little back ground of what i have here, i bought a 73 international travelette from a friend for $700 with the intentions of swapping in a first gen Cummins. As months went by i came across a 90 dodge 3/4 ton 4x4 auto with 150k for $2500. I really wanted to start with a stick but i couldn't find anything within my range, so the rest is history. I planned on doing a motor swap, but after much thought i just swapped the cab. Thus resulted in no room for an intercooler because of axle placement in the wheel well. mind you i did the swap in less than a month as iwas laid off and would have access to a welder our any other tools needed to put the motor farther back on the frame. So I'm pretty much stuck with what i have, but plan on a custom intercooler inside the front bumper as time and money permits. When i first bought the dodge the truck got amazing millage of 24mpg, and was gutless, after the swap it was sitting on 37"hummer take offs, road like crap, wandered all over the road and got about 18mpg. Oh and still was gutless. Then i put on a 4" diamond eye exhaust and it help a little in the power but nothing to rave about, then the big hit came when i bought new 37" Toyo M/T's on i lost a lot of power and fuel suffered to a low of 14 mpgs, but the ride was day and night different! Now what? Well I'm going to turn up the fuel as I've read everywhere, order the M&H M4 fuel pin, 3200 gov spring, and possibly the dynamic advanced timing spacer, but I'm not sure if its worth the money? I just haven't read enough positive reviews, but i guess thats just another reason I'm here, to get some input. also i think the injection pump had been recently rebuilt as all the nuts are coated in red stuff. Well that's where I'm at now, future plans are an nv4500, different tires, maybe a different turbo housing and air & fuel filter, and lots of body and paint!
Attached Thumbnails 73 International Travelette-Cummins-First diesel build-2012-12-14_15-18-03_782.jpg   73 International Travelette-Cummins-First diesel build-2013-03-04_12-23-41_159.jpg
Old Jun 25, 2013 | 03:10 PM
now im trying to figure what guages to get. pretty much buying all new westach, i already picked up the pyro-boost combo and a water temp, but i cant seem to figure out what the exact ohms are from the fuel sender to get the appropriate guage and the vdc range for the oil pressure sender? also anyone know the opperating range of the 727 off hand?
Old Jun 28, 2013 | 01:12 AM
1993firstgennewbie's Avatar
Can I have the bed off the dodge?
Old Jul 7, 2013 | 10:09 PM
CUMMINStagetcha19's Avatar
Rock on man! That's awesome!
Old Jul 8, 2013 | 08:34 AM
tiremann9669's Avatar
Post a build thread with lots of pics
Old Jul 26, 2013 | 12:50 AM
Well finally got around to the pump, installed the m&h m4 fuel pin and the dynamic spacer, turned the fuel screw 1/2 turn from run away (not a great feeling when it does run away) also turned in the star wheel 2 turns. Took it out for a test spin. Results were, at WOT from a rolling idle slow spool from the turbo, black smoke after turbo spooled, then some preformance? I figured after these mods and additions id feel a lot more power, but to be honest i almost feel like performance is worst now. Boost is in the low 20's and the pyro made it to about 1100, was looking for some input on how to maybe dial things in a little better? Going to change the fuel filter tomorrow and maybe turn the star wheel back to stock. Also the pump seemed to be stock, had to remove the collar off the power screw with left small weld on the threads. Other than that I'm up for some suggestions, thanks
shane509
Potential Diesel Owners Forum
Sep 15, 2015 08:41 PM
Dec 18, 2014 03:25 AM
Oct 24, 2014 04:40 AM
Oct 15, 2014 12:30 AM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
