COOLANT LEAK!! CANT FIND WHERE FROM
Old Jun 23, 2013 | 08:37 AM
joker07's Avatar
Default COOLANT LEAK!! CANT FIND WHERE FROM
I HAVE A 2007 6.0 WITH 197000 MILES. I have noticed that after about 1000 miles my truck loses 1/8 to 1/4 inch in the coolant resivor tank. I have checked and had head gaskets checked to make sure i didnt blow a gasket that not the problem, i have checked and have had all of the hoses checked for holes or lose connections. Once again not the problem. I replaced the coolant over flow tank to make sure that wasnt the problem and its not. so im lost. If any one has any ideas i would greatly appreciate it.
Old Jun 23, 2013 | 01:05 PM
bobfbigman's Avatar
Are you only filling it to the MIN line ? it should have a little sticker on the degas bottle because they found that the MAX line was too high for the expansion. does it go empty o does it just go down to a certain point and stop "leaking"? each truck settles out to a sightly different level. You can check the little hose on the EGR cooler to the oil cooler, it is a common leak point.
6.0 egr cooler - Bing Images
see that little blue hose, that is the one, the original might be orange.
Old Jun 23, 2013 | 01:15 PM
joker07's Avatar
ok i konw its coming some where from around the tank, because i wash the motor and then checked to see where i had coolant it is from around the tank. yes once it hits a certain level it stops. but it very low in the tank where it stops and once it gets there i usually dont give it any time to get any lower because i dont want to risk any thing.
Old Jun 23, 2013 | 03:04 PM
bobfbigman's Avatar
My truck settles in just about 1/2" below the min line and will stay that way for years, just monitor it and see if it doesn't stop loosing coolant.
Old Jun 23, 2013 | 03:07 PM
joker07's Avatar
ok, thanks i appreciate the help. il post again if if doesnt stop and continues to lose coolant
Old Jun 24, 2013 | 03:57 PM
Curry's Avatar
Possible you have a small crack in your bottle. I had one and it would loose a few drops every time I started it.
Old Jun 24, 2013 | 06:21 PM
joker07's Avatar
i just replaced the bottle. is there any way that icould be the cap i have on it isnt allowing pressure out when it should ?
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
throttleup22
May 2, 2015 02:04 PM
Mike0885
Feb 28, 2015 03:16 PM
4x4kingx889
Jan 25, 2015 02:02 PM
dieseldummy
6.2L & 6.5L Performance
Oct 1, 2014 07:51 AM
