Grandpa dropped my engine need input
Old Jun 21, 2013 | 04:42 PM
Camarocrazyman's Avatar
Default Grandpa dropped my engine need input
OK so I have been rebuilding this 24v for 2 months. I was litterally going to drop it in the truck today and I get to looking at it and its smashed well come to find out my grandpa termed moving it with the fork lift and didn't check the chains and it fell. Needless to say I don't know if I need to worry about the damages or replace the front gear housing and oil pan. This is actually the 2nd time he has done this but luckely the first time wasn't bad. It did more damage to the concrete then it did the engine
Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
Attached Thumbnails Grandpa dropped my engine need input-uploadfromtaptalk1371850826676.jpg   Grandpa dropped my engine need input-uploadfromtaptalk1371850841691.jpg   Grandpa dropped my engine need input-uploadfromtaptalk1371850874046.jpg
Old Jun 22, 2013 | 08:08 PM
rickf's Avatar
I am going to say the housing and oil pan. The pan could probably be knocked out but that crease in the front above the dent is worrisome. The only worries I would have as far as the main engine goes is the oil pick up. Make sure it is not damaged. How far did it fall? You need to keep grandpa away from the forklift!!!! And anything heavy for that matter.
Old Jun 22, 2013 | 11:26 PM
Antlerking's Avatar
You don't need to worry about oil pickup that's the least of your worries. my father ran over a boulder in Colorado and pushed the bottom of the oil pan up by more than 5 inches and still drove it home with no oil problems. I would say the housing is a for sure! you should still pull the oil pan to make sure everythings ok!
Old Jun 25, 2013 | 09:34 PM
Ramitt's Avatar
Its out and easily accessible so id replace the broken stuff. I'd hate to put it all back together and have to replace something.
Old Jun 26, 2013 | 03:42 AM
97cummins's Avatar
The bell housing needs to be replaced, but the oil pan is your call. And give everything else a good looking over.
Old Jun 26, 2013 | 07:35 AM
Opti-lube's Avatar
FormerVendor
Picture #1 shows some good cracks around the bolt to the right. Replace it and save yourself the hassle down the road!
Old Jun 28, 2013 | 04:07 PM
tiremann9669's Avatar
Grandpa you're banned from the shop
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
hunt4beer
Nov 15, 2014 09:06 AM
Oct 30, 2014 08:10 AM
