no oil pressure
Old Jun 18, 2013 | 06:10 AM
ffemt44169's Avatar
Default no oil pressure
Hey yall. I was commin home from work in my 02 and the check gauge light came on and chimed. Checked my gauges and NO oil pressure at all. Pulled over and checked the oil. Was a little low but not below the add. Topped the oil off and started it up gauge went to about 30 and then after about 30sec it dropps to 0 again. Any suggestions thanks
Old Jun 18, 2013 | 09:45 PM
blacksally's Avatar
probably a bad oil pressure switch or sensor?
Old Jun 20, 2013 | 11:13 AM
ffemt44169's Avatar
Checked with a mechanical gauge 40lbs or so at start up after 30sec or so nothing
. i tried a new oil filter no luck
Old Jun 20, 2013 | 11:16 AM
mysterync's Avatar
Start with the simple stuff, oil pump and check the pickup for clogs before you dig in for a rebuild.
Old Jun 20, 2013 | 05:21 PM
ffemt44169's Avatar
Well pulled the pump it was locked up and the idler gear was broken
Old Jun 20, 2013 | 05:44 PM
Al31031's Avatar
well that will defiantly give you an oil pressure issue bud very disappointing to find but on the bright side you didn't **** anything up so thats the bright side!!!
Old Jun 20, 2013 | 08:30 PM
ffemt44169's Avatar
Yeah, headed to Cummins Atlantic in the morning to get a new one... Through Cummins 90.00 through Dodge 500.00 well worth the 120 mile drive
Old Jun 20, 2013 | 08:37 PM
mysterync's Avatar
Originally Posted by ffemt44169
Attachment 27808
They drop ship
Old Jun 20, 2013 | 08:41 PM
ffemt44169's Avatar
its not that bad of a drive, I usta work across the road from Cummins in Winchester va, and that way I can have it back on the road tomorrow
Durtyd09
Nov 11, 2015 01:43 PM
purnell82
Jul 22, 2015 10:42 AM
jhprice
Mar 29, 2015 09:36 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
