Diesel Auto Power injectors
Old Jun 11, 2013 | 07:38 PM
84chummins's Avatar
Question Diesel Auto Power injectors
I was looking at diesel auto power's website. I was looking at their injectors and it says something about a 1st gen core charge and core deposit required? What does this mean? thanks for any help
Old Jun 11, 2013 | 09:30 PM
Benjamin's Avatar
Bombardier
it means, when you order the injectors, they charge you for the cost of the injectors, PLUS a "core charge" of $150. then when you receive the new injectors, you remove the old ones, and send them back in and you get the core charge back.
OR you can remove your old ones and send them in first to eliminate the core charge.
Old Jun 11, 2013 | 09:52 PM
84chummins's Avatar
oh thanks for explaining. I was thinking about maybe buying some 5x18s. does anyone know how much hp those are rated for?
Old Jun 11, 2013 | 10:35 PM
Benjamin's Avatar
Bombardier
5x18's are HUGE, they would work well for a "large" set of twins....
Old Jun 12, 2013 | 08:27 AM
84chummins's Avatar
so if I would run an hx35, would 5x16s be alright?
Old Jun 12, 2013 | 01:28 PM
Al31031's Avatar
i think the 5x14's would be sufficient for an hx35
Old Jun 12, 2013 | 05:40 PM
Benjamin's Avatar
Bombardier
5x14's are equivalent to Marine 370's but burn cleaner and make more power IF they are the correct spray pattern.
an HX35 would be a bit on the small side unless you have a stock fuel plate and a HUGE exhaust housing and an intake, and exhaust, and a decent intercooler. if you are non intercooled then I wouldn't do it.... just me personally. I'd look into a 62mm turbo...
Old Jun 12, 2013 | 06:39 PM
84chummins's Avatar
I just read that an hx40 is a 60 mm turbo. the h1c is supposedly a 50 mm turbo?
Old Jun 12, 2013 | 07:21 PM
Benjamin's Avatar
Bombardier
depending on how many blades the HX40 exhaust wheel has will make it either work well or totally suck *****.
also the shaft is the same size as an HX35 and because of the larger mass of the wheels, they have been known to break shafts....
May 10, 2015 10:57 PM
May 7, 2015 11:50 AM
May 7, 2015 01:40 AM
May 6, 2015 03:20 PM
May 6, 2015 05:11 AM
