Door stuck
Old Jun 11, 2013 | 05:39 PM
codyawise's Avatar
Default Door stuck
My 99 quad cab rear driver side door is stuck. I used to be able to push on top and pull handle to open it but now it won't open at all . How can I get it workin again?
Old Jun 11, 2013 | 08:59 PM
dango's Avatar
mine is the same way. i took the door panel off and discovered that the rod that pulls the bottom latch has broken leaving me no way to pop the bottom latch. this may have happend to yours. its very common. the only way to know for sure is to start diggin
Old Jun 14, 2013 | 01:15 PM
codyawise's Avatar
Where can you get them kinda replacement parts
Old Jun 14, 2013 | 01:19 PM
dango's Avatar
Probably any auto store. Since I can't get the bottom hinge popped without cutting into my door I just left it broken.
Old Jun 18, 2013 | 12:32 PM
AlmostClassy's Avatar
I have the same problem; not important enough for me to cut into my door yet, although it's a huge pain in the ***.
Old Jun 18, 2013 | 04:33 PM
BarryB's Avatar
Yeah mine was doing that, been awhile since I did it, But I think I removed the handle. was able to get inside to reach the latches and get the door opened. Then replaced the broken clip. I did remove the door panel. Those clips can be gotten at most auto parts stores. Usually in the help section.
Old Aug 1, 2013 | 12:59 AM
dango's Avatar
Ok so I finally got a day off and was able to work on my door some more. I actually got it to open. All you need to do is take the door panel off the rear door, take the little vent door out (its the little square box) behind the vent door there are 3 small nuts. I tightened them down until they broke. you will need to unlatch the top latch and keep it propped open so the door can move up. After unlatching the top use a pry bar to push the door up off the broken bolts (you may have to wiggle the door and help pull up on it). once the door pops open all you need to do is break the old latch off and either replace or just use the top which is what i'm doing for now. if you have any questions feel free to call or text 217-493-5140
Old Aug 8, 2013 | 02:06 PM
Ratherbepulling's Avatar
in most cases when the doors arent used often the linkage from the handle to the bottom latch gets rusted, in my case just soak the latch with wd40 from the inside of the truck fold up the seat and have your biggest buddie kick on the door close to the jam and after a couple times it will come open then use some more wd on the latch once the doors open and itl work forever no need for taking the panels off (i did one that way and lost the spring from taking it apart so now the handle doesnt retract) but the bigfoot method works very well
Old Aug 9, 2013 | 11:22 AM
rodbuilder's Avatar
car-part.com
Works for me!!!
Old Aug 10, 2013 | 08:53 PM
tiremann9669's Avatar
Just using the top latch could be dangerous in an accident since the front door latches to the rear door
