Hoping it's not my VP44...Help!!!
Old Jun 11, 2013 | 01:04 PM
TarponTime's Avatar
Default Hoping it's not my VP44...Help!!!
Hello, I currently own a 1999 2500 24 valve and just recently it has had a starting problem. It cranks, but wont start. Ive checked my lines from the lift pump to the injector pump and have good amounts of fuel coming out. I crack lines 1, 3, and 5 from the motor and have someone start it and only little fuel comes out. I have the diablosport power puck which plugs directly into the vp44. From what ive read so far it can be a number of things which could lead to a no start. I have no fuel pressure gauges or anything like that, and all my pumps are stock. any help would be greatly appreciated to get my beast back on the road.
Old Jun 11, 2013 | 07:18 PM
pimba24's Avatar
You may want to get a scanner and check your codes it sounds like your injection pump may be on its way out if it isn't already.
These are a list of the most common codes condemning your VP44:
P0216 (often referred to as the code of death and most common code for VP44 pump failure)
P1688
P1689
P0215
P0251 - P0260
Old Jun 11, 2013 | 07:26 PM
shellinger's Avatar
did you already unplug the diablo puck tuner and try it?
Old Jun 11, 2013 | 08:20 PM
TarponTime's Avatar
Im having a friend come over with a decent scanner to look for embeded codes. I also have not tried to start the truck without the powerpuck plugged in so I'll try that as well. As for all those codes...Ill keep them in mind, Im just praying and I mean PRAYING it's some dumb sensor. Thanks for the replies guys.
Just had it scanned...P1688 oh yay!
Last edited by TarponTime; Jun 11, 2013 at 08:20 PM. Reason: Automerged Doublepost
Old Jun 14, 2013 | 08:49 PM
Ramitt's Avatar
Get a fuel pressure gauge! Chances are if you have a good amount of fuel up to the vp and very little coming out of the lines then its prob a dead vp.
Old Jun 16, 2013 | 04:32 PM
pimba24's Avatar
Yea I'd say you need a new VP. On the bright side they arn't bad to change and saves you a couple bucks.
Old Jun 16, 2013 | 07:17 PM
dabeck's Avatar
Replaced mine myself and works fine also replaced the injectors at the same time. I think the price has also gone down some on the pumps.
justinsbeck
Jan 18, 2016 12:15 AM
Big Bill
Price Quote - Request A Price
Mar 19, 2015 11:13 AM
DeLuzGN
Mar 17, 2015 08:08 AM
JPT18
Dec 30, 2014 11:37 AM
somarillw
Dec 15, 2014 12:00 AM
