help, truck acting up.
Old Jun 10, 2013 | 03:05 PM
jimmydiablo's Avatar
Default help, truck acting up.
Driving home on freeway. All of the sudden check engine light, abs ligh on solid.. tow/haul flashing..
Transmission engaging off and on. I idled home about 6 miles
But no clue where to start looking. Its a 2003, 6.0 with 134k on it.
Old Jun 10, 2013 | 04:00 PM
F355911TT's Avatar
Buy an Auto Enginuity scanner with ford package for 350$, if you have windows based PC. Or amazon has scan gauge 2 for 140$. it will atleast give you an idea before you take it anywhere of what trouble codes is being thrown. The A E is a very thorough diagnostic tool. The scan gauge will do basic minimum monitoring, ICP, IPR, ficm voltage, etc.
Amazon.com: ScanGauge II Ultra Compact 3-in-1 Automotive Computer with Customizable Real-Time Fuel Economy Digital Gauges: Automotive Amazon.com: ScanGauge II Ultra Compact 3-in-1 Automotive Computer with Customizable Real-Time Fuel Economy Digital Gauges: Automotive
http://www.dieselpowerproducts.com//...FaU5QgodfwMADg
Old Jun 10, 2013 | 05:26 PM
Will do. Just check fuses. One blown. Replaced it now won't even crank
Got it started, now no codes. But fuel gauge reads low (has full tank) and there is a clicking noise from fuse panel area. Still running like crap.
Last edited by jimmydiablo; Jun 10, 2013 at 05:26 PM. Reason: Automerged Doublepost
Old Jun 10, 2013 | 06:27 PM
F355911TT's Avatar
probably hydrolcked from too much fuel and no combustion, if you're hearing a clicking from fuse panel that sounds like a relay working improperly, this probably won't change anything but crawl under driver side where the fuel pump is, there is a 6 millimeter allen set screw for draining water, drain the water out of the fuel pump. This is a pita without proper socket, but while you're there you can pull filter off and see if there's a bunch of trash in there. Get ready as about 16 oz of fuel will come out on to the floor, you could have a fuel pump going out, you should check the pressure at the regulator where 2nd fuel filter is, another set screw, I think 6 mm also. However It requires an npt fitting to put gauge on. I bought my fuel pressure gauge from harbor freight cheap, all you need is something that will read up 100 psi. The fittings in kit will not fit ford diesel. I put several feet of hose from auto part store to run it under the hood to check pressure at idle and driving conditions.my palm would come on but it had 0 pressure. rockauto.com seles motorcraft filters and pump cheap. Both filters 48$. Motorcraft Pump was 252 on eBay.
forgive the grammar and punctuation I'm speaking into a tablet
http://www.ebay.com/itm/Motorcraft-PFB101-Electric-Fuel-Pump/320719396478?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D8286268789379869882%26pid%3D100033%26prg%3D1011%26rk%3D1%26sd%3D320719396478%26
http://www.rockauto.com/m/mobilecatalog.php
Old Jun 11, 2013 | 12:12 AM
Thanks for next route. I use my phone so grammer and spelling are always off a bit
Old Jun 26, 2013 | 10:27 PM
problem ended up being a fan clutch. the harness shredded. while he was at it I had him do the water pump, and all pullies. running great now. I am going to invest in a coolant filter before my a e scanner.
doublehbar
13
Aug 9, 2015 12:35 AM
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
