1st time diesel owner looking for more power
Old Jun 8, 2013 | 03:43 PM
stevenjames92's Avatar
Default 1st time diesel owner looking for more power
hi guys i am a first time diesel owner, i went out and picked up 99 dodge 2500. it has 220xxx miles on it a newer tranny, straight piped, and a K&N air filter. now i wanted to chip the truck, but i have heard i need to do other upgrades as well as the time time? if someone could pass on a little knowlage that would be awsome!!
thanks for the help!
Old Jun 8, 2013 | 06:10 PM
lauber_03's Avatar
lift pump first! also get a gauge for it, dont want under 10psi at wot. some programmers have fuel pressure monitor as in the edge j/w attidude. you just wanting some minor power still towing, or no towing lots of power?
Old Jun 9, 2013 | 12:15 AM
not really looking for towing purposes, mostly just looking for power. and whats a good moderately priced lift pump?
The goal is to roll coal!
Last edited by stevenjames92; Jun 9, 2013 at 12:15 AM. Reason: Automerged Doublepost
Old Jun 9, 2013 | 01:01 PM
lauber_03's Avatar
you can get a good pureflow raptor frrp for under 300. programmer wise there is quite a few that'll do. i like my edge personally cause it can monitor a lot at once.
Old Jun 10, 2013 | 01:17 PM
vcustoms86's Avatar
If thats the goal then take the truck back. You can make power without alot of smoke. Its more impressive to make tire smoke than exhaust smoke. Plus every window licker out there running around blowing black smoke at everyone is why the EPA has come down so hard on diesels in the last 2 years. Please dont be like them. "Roal Responsibly".
Old Jun 11, 2013 | 11:36 AM
with power comes coal. im not that jerkoff thats gonna throw coal everywhere he goes. only on occasion to show it off a little bit.
Old Jun 11, 2013 | 11:52 AM
vcustoms86's Avatar
With over fueling and a lack of air, comes smoke. Tune it right it will barley smoke. Plus, the more it smokes, the more fuel you are wasting and thats money out of your pocket. With that, the truck needs a lift pump. The factory one on the VPs suck so that should be the first thing. An Edge Comp box would be good if you want to do your own guages or the Edge Juice if you want built in gauges. If its an auto I would put money into that before the programmer. If you have a manaul you can do the programmer and see how your clutch will handle it and upgrade that if it wont hold it.
Old Jun 11, 2013 | 04:46 PM
it is an auto, what kind of upgrades would you suggest for the tranny?
Old Jun 11, 2013 | 07:11 PM
pimba24's Avatar
Upgrade your lift pump first. Like everyone else said they're known to fail which in turn wipes out your VP44 and then your talkin 1100 bucks minimum. After that i'd look, again as was stated, to upgrade your trans. The toque convertor and valve body are the weaker points in these transmissions due to lower shift pressures. It all depends on how much power your looking to make. I have a smarty with a edge comp box hot unlock stacked on mine and it really made her come alive but i have to watch now cause she will push over 40psi. I guess it all depends what horsepower range are you looking to achieve.
Old Jun 16, 2013 | 09:41 PM
chadcycle 2500's Avatar
I'd put on arp headstuds too,bigger exhaust
May 10, 2015 10:57 PM
May 7, 2015 11:50 AM
May 6, 2015 03:20 PM
May 6, 2015 05:11 AM
Mar 19, 2015 08:10 AM
