Air leak.
Old Jun 5, 2013 | 07:18 PM
mossyoak54's Avatar
Default Air leak.
Ok guys on my 01 2500 I have acquired an air leak that is letting the system loose prime when it sits. Only takes about 30 min to do this. I've replaced o ring washers on feed side line, and on the return side at the banjo bolts. Also replaced the T fitting and gaskets. Replaced the fuel bowl drain, and the entire return line. All injector lines are good, and no sign of diesel in oil for crossover tubes. Now when I did the T and the return line it had no issues for about 24hrs. Then it came back so I went through and checked everything again today. No signs of leaks or faulty connections. Anybody have some ideas?? Because I'm all out.
Sent from the mans IPhone.
Old Jun 7, 2013 | 11:13 AM
Al31031's Avatar
have you tried the check valve on the vp?
Old Jun 7, 2013 | 12:30 PM
MillerBoyzDiesel's Avatar
Have you replaced the orings on the tubes?
Old Jun 8, 2013 | 06:53 AM
mossyoak54's Avatar
I've replaced o rings on everything . And yes check valve on VP is good. I'm about 99% sure it's the banjo at back of the head. It keeps backing out.
Old Jun 8, 2013 | 09:32 AM
Al31031's Avatar
yupp i just did the banjo bolt on the back of mine. It was leaking real bad put the o rings in and no more leak
ctjkelley
Jun 3, 2015 06:01 AM
carid
Diesel Bombers Sponsors
May 27, 2015 07:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
petew
Oct 25, 2014 09:29 PM
