Manual transmission coolant line routing
Old Jun 4, 2013 | 11:47 AM
dieseldude848's Avatar
Default Manual transmission coolant line routing
Does anyone have a diagram or picture of how the small coolant lines on the passenger side of the block next to the oil filter are routed on a 24v 5 or 6 speed truck? I took out the auto trans heater on the side of the block when I did my swap, and just by passed it with a piece of heater hose until I could figure out how the factory manual trucks are set up.
Old Jun 4, 2013 | 04:06 PM
BBD Tech Support's Avatar
I believe they are blocked off right at the engine? With NPT style plugs
Old Jun 4, 2013 | 10:48 PM
A picture would be best
Old Jun 5, 2013 | 07:16 PM
Anyone?!
Old Jul 23, 2013 | 05:37 PM
Cornfed 1020's Avatar
i just did the same thing on mine and i went to the local plumbing store and bout an elbow and ribbed fitting for the new hose for cheaper then the block they wanted trhough dodge. i also bought a plug and just plugged the extra hole they had for the line warmer. i havent tried my setup out yet since im deployed and it was my project while i was waiting to leave but that is what i did man
Old Jul 23, 2013 | 11:21 PM
So the 2 lines that go to the trans warmer can just be plugged off? If so that's what I'll do, I rigged it up so it still circulates as if the cooler was still in place.
Old Jul 23, 2013 | 11:57 PM
I TOOK IT OFF COMPLETELY AS WELL BUT WHERE MINE WENT BACK INTO THE BLOCK I PUT A PLUG THERE AND THEN RAN BOTH MINE FROM THE HEATER CORE BACK TO STOCK. DO YOU HAVE A LINE WARMER ON YOU MANUAL I HAD THE AUTO THEN CONVERTED TO MANUAL LIKE I SAID IF I WAS HOME I WOULD HAVE UPLOADED PICS OF IT FOR YA TO SEE BUT IM DEPLOYED HOPEFULLY THIS HELPED YOU
Old Jul 24, 2013 | 01:57 PM
theres no way to put a line warmer on a manual unless there was some type of pump system. i also swapped mine from auto to manual...
Old Jul 24, 2013 | 05:19 PM
Yea i didnt think there was but never know with aftermarket and customizing people do but yea i have a lot longer hose that is off the other truck i swapped the system out of and he had it routed in a wierd spot that I didnt like but he had his working just fine buy routing it down under the turbo and back up through if i remember correctly i was going to get some clamps and see how it would look running it up top by the head idk how that will work but that is what he had done and it wasnt overheating or anything but i wrapped my hose as well to make sure it wouldnt melt incase it did get hot. Also heard you could get steel braiding and put that around your line as well. I wish i would have remembered exactly but days over here blend together and i forgot some stuff already
caissiel
Sep 24, 2015 05:37 PM
mcompton1973
Feb 11, 2015 12:00 PM
BubbaDT55
Dec 7, 2014 08:52 AM
motormayhem
Nov 16, 2014 02:13 PM
