AIR FILTER MONITOR
Old Jun 4, 2013 | 06:38 AM
mdlollis's Avatar
Default AIR FILTER MONITOR
What would cause the air filter monitor to get so hot that it melts and comes apart?2004 6.0
Old Jun 4, 2013 | 11:03 AM
bustedknuckles's Avatar
One possibility is your engine compartment is getting hot; if that's the case, I would suspect the engine is the source? If your not getting a high temperature reading on your dash, the sensor could be bad.
Is the engine blowing coolant out the degas bottle?
Old Jun 4, 2013 | 05:50 PM
bobfbigman's Avatar
I just leave mine unplugged but I also clean my filter on a somewhat regular basis. I would think it would have to be a set of bad contacts in it, it is just a switch.
Old Jun 6, 2013 | 08:55 AM
mdlollis's Avatar
The temp. gauges have not shown any have temps.It's not blowing coolant,but it is blowing bubbles in a test container.Most likely ahead gasket,the egr has been deleted.
Old Jun 6, 2013 | 10:01 AM
I'm going to make a wild guess and say that your temps are not showing high because the temp sensor does not have fluid contacting it. A temp sensor will only show the real temperature if fluid is contacting it.
So, my guess is your head gaskets are blown and you have gas, either steam or exhaust, in your cooling system.
The air filter monitor is melted because your engine compartment is indeed hot...very hot.
jeffersonl
Nov 15, 2015 07:35 PM
Joebritt3210
Feb 11, 2015 01:44 PM
fire1296
Feb 4, 2015 06:15 PM
offroad00
Oct 27, 2014 06:50 AM
jeffersonl
Oct 25, 2014 06:46 AM
