compound questions
Old Jun 3, 2013 | 05:16 PM
lauber_03's Avatar
Default compound questions
Just moved to oregon, elevation here is a bit higher then where i came from. anywhere from 2500 feet to 10,000. i do tow and i have 150 injectors, thinking of compounds for lower egts and a bd intercooler. any suggestions would help. thanks in advance
Old Jun 11, 2013 | 01:18 AM
01quadcab's Avatar
don't waste money on a intercooler you wont gain much if any. I would get a 475 to put under the 62 then get some 200hp sticks and it will spool and drive great. get the 1.10 housing on the 475. I live at 3900' and had a similar setup and it worked well. you will need to o-ring the head, but you can drive it till it goes.
Old Jun 11, 2013 | 10:53 AM
jkidd's Avatar
compound turbos is a great way to go.
might be able to make enough reduction in egt with water/methanol (like snow MPG max kit where you can set the injection to come on at 2-3psi over cruising boost to lower smoke and egt.
cam, tunnel ram intake plenum, gasket matching exhaust ports will all help as well.
Renteria1217
Apr 16, 2015 11:38 PM
Mar 20, 2015 08:20 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
