valve adjustment ,, 6.2l
Old Jun 3, 2013 | 12:26 PM
bearius's Avatar
Default valve adjustment ,, 6.2l
hi i just swap an 6,5l diesel for an 6,2 l disel 1988 year , and now i trying to figure out how to adjust the valves , they make a little rattle and some one told me they neede an adjustment , i am a mechanic but not for v8 s
it rruns good and doesent smoke :9 yhink thats a good thing but need some adwice to adjust the valves for now
Old Jun 3, 2013 | 05:19 PM
racer55's Avatar
There is no valve adjustment available,they are hydraulic lifters that make up the lash setting within their bore/piston combo.
These engine do have diesel rattle that is pretty pronounced.
One problem that does occur in the valvetrain and that is the nylon locating washers fail over time and that can let rockers wander on the shaft and loose contact with the valve and pushrod giving you a miss and a rattle best case.
Old Jun 3, 2013 | 08:35 PM
acelawn's Avatar
Racer55, could this "nylon Locating washer" cause the cylinder to stop firing, I have a 92 6.2. 130k, that just developed a dead miss, front cylinder on passenger side not firing, pulled injector and it checked out, makes no knock, no tick, no more blow by than before the miss, not coughing back through intake, looks like a chore to get the rocker covers off, so I have not started that yet, any thoughts?
Thanks
Old Jun 4, 2013 | 06:49 AM
racer55's Avatar
Sounds like a good place to start looking.
Old Jun 4, 2013 | 09:43 AM
acelawn's Avatar
Thanks
Old Jun 6, 2013 | 05:48 PM
acelawn's Avatar
Racer55
pulled the rocker cover today, intake valve plastic/vinyl retainer out to lunch
any reason to think something caused the failure?
I plan to replace them all, the one that broke, rocker is spinning on shaft, push rod just hanging out, what is the best, easiest way of getting the rocker and push rod back in place
Thanks
Acelawn
Old Jun 7, 2013 | 09:55 AM
racer55's Avatar
They just get old and weak and shatter.
Undo the rocker shaft evenly from end to end,replace the spacers and then re install the shaft by aligning the rockers and pushrods and slowly and evenly tightening down the shaft to spec.
RA113024
Mar 13, 2016 07:42 PM
jeremiah1
Jul 21, 2015 06:35 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
behrendt1061
Dec 4, 2014 05:49 PM
