rough idle when warm....... help
Old Jun 1, 2013 | 03:46 PM
fmx23's Avatar
Default rough idle when warm....... help
Got two codes for a lift pump which has been replaced and a crank sensor which has not Been replaced. When the truck is warm and in park it idles somewhat rough like it has a small.misfire. but when you press the brake to put a load on the engine it idled fine. Can the cps cause a small misfire/bad idle??
Old Jun 3, 2013 | 05:25 PM
lauber_03's Avatar
yes it can cause a rough idle. i had a similar issue. replaced the cps which is kinda annoying to do being behind the vp but fixed the problem
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
Jan 22, 2015 08:38 PM
Snoobly
Dec 11, 2014 11:59 AM
cdetterer
15
Dec 8, 2014 08:46 PM
99stackedpowerstroke
Oct 8, 2014 07:06 PM
