Best chip/tuner for 24v
Old May 31, 2013 | 06:25 AM
24vcummins99's Avatar
Smile Best chip/tuner for 24v
Hey guys I'm new to this site and to the diesel world, I'm getting a 1999 cummins 5 speed, and has 129,000 miles. What's the best tuner for it . It has a 4" turbo back exhaust and a K&N intake. I was looking at the edge CTS but it was says it dosnt add horse power it just monitors everything. I want something that you can get good gas mileage but at the same time change the settings and blow black. Thanks guys!
Old May 31, 2013 | 09:13 AM
MillerBoyzDiesel's Avatar
Sounds like you need an edge comp! The CS and CTS are monitors for the juice box.
Old May 31, 2013 | 01:01 PM
jkidd's Avatar
edge juice with CS or CTS monitor will be great. If you want to do mechanical gauges the comp is a great choice. your stock turbo will be fine with the extra 120HP
Old Jun 1, 2013 | 09:27 AM
Yea that's exactly what I was looking at. There around a $1000, which isn't to bad
I heard the lifter pump or fuel pump is a must to replace with the 99 24v... How come?
Last edited by 24vcummins99; Jun 1, 2013 at 09:27 AM. Reason: Automerged Doublepost
Old Jun 1, 2013 | 12:15 PM
codyawise's Avatar
Replacement of lift pump is a must if ya want to add extra power so you don starve the injection pump. The injection pumps need to have proper fuel pressure or else it'll take a dump on ya
Old Jun 1, 2013 | 01:09 PM
Alright is that hard/expensive thing
Old Jun 1, 2013 | 01:25 PM
UglyTruck's Avatar
its not too difficult. the issue with the stock lift pump is that when they go out there is nothing to tell you it went bad. there is no warning light, no pressure gauge, the pumps themselves are undersized IMO but you need to understand that the high pressure fuel pump (the VP44) is cooled by fuel flow so if it is starved for very long it gets hot and generally fries the electronics. A VP44 will run you anywhere from $1000 to $2500 depending on where you get it and if it has been turned into a high flow unit.
the first symptoms of a bad lift pump are usually the driveability symptoms of a bad VP44 and you then find out that the lift pump crapped out at some point and has been starving the VP44. it will probably cost you around $600.00 (Im guessing here so a vendor needs to chime in) to upgrade to a Fass or a Raptor setup but it will give you way better fuel flow and better filtration in addition to being cheap insurance against VP44 failure.
Also, if you run any kind of tuner that taps into the fuel pump wiring that will void the warranty on the vp44 regardless of who you buy it from or how old it is.
at 130k I would be surprised if that truck still has the stock lift pump on it, but if it was a fleet vehicle or if the previous owner was a "Dealer only service" person it might.
Old Jun 1, 2013 | 10:39 PM
silverbeast1345's Avatar
Just installed my edge comp box loads of power deaf beats the adrenaline I had in earlier
Old Jun 2, 2013 | 07:35 AM
How can tell if it is stock or not?
Awesome! That's what I wanna hear. It's all plug and play right, nothing to crazy
Last edited by 24vcummins99; Jun 2, 2013 at 07:35 AM. Reason: Automerged Doublepost
Jason7three
Nov 15, 2014 11:05 AM
