a/c actuator
Old May 30, 2013 | 01:04 PM
jeff9094's Avatar
Default a/c actuator
howdy boys and girls
say i need to replace my a/c actuator. is this located behind the glove box??
2005 f350 / 6.0 xl cc 4x4
Old May 30, 2013 | 03:57 PM
bobfbigman's Avatar
AC actuator?? what are the symptoms? and how do you know it is bad?
Old Jun 4, 2013 | 08:41 PM
jeff9094's Avatar
I'm only getting defrost with no other options.....after speaking with numerous parts houses and fellow powerstrokers. Seems to be logical after it being 9 yr old truck and a daily driver......
What you thinking?..?
Old Jun 6, 2013 | 04:47 PM
bobfbigman's Avatar
Defrost is the default setting,meening if the vaccum pump is not working or you have a leak in the 4X4 system then it will only go to defrost, alot of people have had the problem when they turn the 4X4 on the heater goes to defrost because they have a cracked vaccum line or a leakins seal in the front hubs/the hubs are vaccum operated. just behind the battery on pass side there is a vaccum resivoir and then the pump is right behind that, you can turn the key on then remove one of the vaccum lines off the pump and the pump should come on.if not then either there is a blown fuse or the pump is bad, most likely the pump is bad.
Old Jun 7, 2013 | 05:48 AM
jeff9094's Avatar
i will look at this today after work , your a good man ....
will let you know
Old Jun 19, 2013 | 06:03 AM
jeff9094's Avatar
morning bobfbigman
say i gotta tell ya thankyou , you were correct ! found a vacum hose that came off......and all is working just as it should
Old Jun 19, 2013 | 04:35 PM
bobfbigman's Avatar
Cool, haven't heard of anyone having the actuator mess up on them, well that was a cheap fix
Old Jun 19, 2013 | 08:46 PM
jeff9094's Avatar
i would say soo......heres a beer or three to you sir , again thankyou
jeff
Maclain Marsh
Jul 13, 2015 06:23 PM
Jladanyi
Jul 4, 2015 02:43 PM
joldfield
Jun 22, 2015 04:27 PM
CumminsCoalRoller24/7
May 5, 2015 08:55 PM
JasonG.
Ford Powerstroke 08-10 6.4L
Feb 26, 2015 08:51 PM
