Ildes fine but revs up when I hit the throttle
Old May 29, 2013 | 06:08 PM
FatherV's Avatar
Default Ildes fine but revs up when I hit the throttle
I have a 2000 and it has a code( I cant remember which one, but it aimed at the map sensor) but it ran fine. I let the battery die, and after I charged the battery It will idle fine but as soon as I tap the throttle It revs up and wont start unless I shut it off. I have reset the apps a couple times with no change. Any ideas? I am puzzled because it ran fine before I let the battery die.
Old May 29, 2013 | 08:59 PM
Al31031's Avatar
unhook the battery over night then try again in the morning dont hold me to this but iv seen it work before and it costs you 0 dollars
Old May 30, 2013 | 04:25 PM
FatherV's Avatar
I have tried that before and it didnt work either
Old Jun 5, 2013 | 01:59 AM
FatherV's Avatar
I was told that the pcm might have lost its memory due to having the battery dead too long. And that it could take between 30-100 miles of driving to restore. Does this sound good to anyone else? And I just rescanned it and came up with p0336 and p0237. does either code sound like maybe the cause or just need to drive it and relearn?
1stgenswap
Nov 3, 2014 09:45 PM
