Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
Which Tires For Pulling?
Old Apr 1, 2008 | 08:34 AM
pennsylvaniaboy's Avatar
Default Which Tires For Pulling?
so i dont have a deisel right now but im planning on pulling my '79 1 ton chevy. i have a boosted '96 vortec 350,sm465,np205,4.10s. i have 3 options for tires...38" super swampers, 41" firestone all tractions, and 285 kelly rvt's which would be the best option?
Old Apr 1, 2008 | 09:38 AM
06 DIESEL's Avatar
Your best bet is going to be the 285's, the other two are going to be really really hard on your drive train and hard to turn with any kind of speed.
Old Apr 1, 2008 | 10:08 AM
well i thought id ad some more info. its 6" lift with drop hitch and welded rear diff....
Old Apr 1, 2008 | 01:15 PM
RSWORDS's Avatar
If you ae serious about pulling it... Drop the lift and run the 285's. Get a hitch set-up that is as high as your allowed in the class you are running.
Old Apr 1, 2008 | 01:27 PM
DangerousDuramax's Avatar
Yep, what he said.
Old Apr 2, 2008 | 05:51 AM
well guy this truck in only pulled a few times each summer so not that serious. i do have a uber beefy drop hitch made by a local welder....not the kind you can buy in stores...so think the 285's?
Old Apr 2, 2008 | 07:31 PM
RSWORDS's Avatar
we where not talking about how the hitch was made, what we are saying is that a higher hitch gives you a better pull... But they limit how high off the ground it can be. Usually about 26"
Old Apr 3, 2008 | 06:30 AM
im not sure i follow ow a higher hitch gives better pull. in a tractor the higher you go the more it lightens the whole tractor
Old Apr 3, 2008 | 07:15 AM
Jazz's Avatar
What ever your pulling, you want that point lower than your hitch point on whatever your pulling with so it pulls down on the pulling vehicle
Old Apr 3, 2008 | 08:10 AM
IC Smoke's Avatar
MmmmMMm trucks with lifts usually break something
285's for pulling but run the others for looks so its not jacked up and your running tiny tires
