pulling 5th wheel camper
Old May 27, 2013 | 08:40 AM
dkapp0802's Avatar
Default pulling 5th wheel camper
im planning on buying a 5th wheel camper and im just trying to figure out what i should do before i start pulling it?
what kind of mileage should i expect?
Old May 27, 2013 | 11:41 AM
bobfbigman's Avatar
I would just service the trans, new filters and fluid. One of the most important things to do is to have your oil cooler checked, oil temp and coolant temp should never be more then 15deg apart, if it were me and the oil cooler has never been rebuilt I would do that and then add a coolant filter to prevent the oil cooler from clogging up again. If you have over 50k on the motor without a coolant filter then a oil cooler rebuild would be recommended. you might want to rethink your stack too, all that heat and soot won't be good for the front of your trailer.
Old May 27, 2013 | 12:03 PM
dkapp0802's Avatar
that oil cooler has crossed my mind a time or two but have never done it. im not sure if it was ever dont either.
when i put the stack in i though ahead with it and made the up pipe the goes into the stack so i could just turn it 90 degrees to make it become a turn down.
oneloud59
May 16, 2015 10:00 AM
carid
Group Buy
Apr 8, 2015 06:11 AM
6.5dieselman
Feb 26, 2015 04:45 PM
94ifs
For Sale
Oct 23, 2014 01:35 PM
