Need more mpgs
Old May 26, 2013 | 09:04 PM
96f350tx's Avatar
Default Need more mpgs
i need to find out a way to get a lot better then 8 mpg out of my 96 f350 srw any suggestions ive heard a lot about ugrading the turbo housing and a ts chip any suggestions?
Old May 26, 2013 | 09:16 PM
joebob3093's Avatar
Moderator
What size tires do you have and what gears?
Old May 26, 2013 | 09:21 PM
96f350tx's Avatar
33x10.50 and stock gears
Old May 26, 2013 | 09:24 PM
joebob3093's Avatar
Moderator
stock gears are either 3.55s or 4.10s. you have some other problems, you should be somewhere around 15ish
Old May 26, 2013 | 09:40 PM
96f350tx's Avatar
it is a 4wd
Old May 28, 2013 | 08:11 AM
96f350tx's Avatar
do you know of anything that i can check or clean that would help in this situation?
Old May 28, 2013 | 09:51 AM
glfredrick's Avatar
Switch everything that holds oil to synthetic. If you are running aggressive off-road tread tires, they will suck up several mpg. What else is sticking into the wind, rear rack, big mirrors, etc.? All effect mileage. Are your injectors all popping correctly? Many issues with wiring harness under the valve covers that effect performance & mileage. Exhaust plugged up or undersized? How much extra weight are you hauling around that you don't need to haul?
Questions above can show some mpg improvement if addressed.
Sent from my Galaxy Nexus using Tapatalk 2
Old May 28, 2013 | 10:49 PM
96f350tx's Avatar
i am running all terrain tires and i have a 3 inch down tube to a 4 inch tube to a 5 inch tip and i am not hauling anything extra i will check the wiring harness under the valve covers and as far as i know the injectors are fine but i dont k now how to check them
Old May 29, 2013 | 06:22 PM
Kroppy's Avatar
heavy foot? i have the same set up as you and i can see 20mpg
Old May 29, 2013 | 06:43 PM
96f350tx's Avatar
honestly i only run it hard when a cummins wants to f### with me other then that i am pretty gentle on the gas that sh## is too expensive
