1993 6.5 TD Cooling System Leak
Old May 26, 2013 | 11:19 AM
Kurt M's Avatar
Default 1993 6.5 TD Cooling System Leak
I have a 2WD K2500 pickup. Had small leak where top heater hose connects to coolant manifold. Where the heater hose tees off there is a connector. The connector nipple broke off in the manifold. I purchased two different extractor tools but neither would remove the broken nipple. How can I extract the remainder of the nipple - it seems to be almost impossible to remove. Removed the manifold but having troule replacing it. I don't even know what the piece is called. Help if you can! Thx, Kurt
Old May 26, 2013 | 05:57 PM
racer55's Avatar
Take the coolant crossover manifold to your local engine rebuilder and let them take out the broken fitting-cheaper than replacing the manifold.
Old May 26, 2013 | 06:31 PM
hookedup50's Avatar
You can put the manifold in vise and carefully air saw out the broken fittingwith several tapered cuts then carefully chisel it in on itself. People generally replace fitting with barbed one.
old chevy
Sep 2, 2015 08:42 AM
glasspack
Jul 29, 2015 11:04 AM
markv8993
Jun 21, 2015 12:24 AM
Gomerpile79
Apr 9, 2015 03:45 PM
yz450f269
Mar 15, 2015 08:56 PM
