MISFIRE/ POP AT IDLE HELP
Old May 25, 2013 | 01:42 AM
fmx23's Avatar
Default MISFIRE/ POP AT IDLE HELP
TRUCK HAS A SMALL MISFIRE/ POP WHEN THE TRUCK IS IDLING IN PARK AFTER IT IS WARMED UP AND DRIVE IT FOR A WHILE. IT DOES NOT HAPPEN ON A DAILY BASIS THOUGH. I DID GET A CODE FOR A CRANK SENSOR BUT HAVE NOT CHANGED IT. THE CEL IS NOT ON SO I HAVENT PAID MUCH ATTENTION TO IT EVEN THOUGH I PROBABLY SHOULD. CAN THE CPS CAUSE A MISFIRE IF ITS NOT FUNCTIONING RIGHT?
****WHEN YOU PRESS THE BRAKE PEDAL TO PUT A LOAD ON THE MOTOR IT IDLES SMOOTH AND FINE***
*** THE TACH DID DROP TO ZERO ONCE BUT HAS NOT DONE IT AGAIN SO FAR***
STOCK MOTOR WITH NEW INJECTION AND LIFT PUMP
ITS A 2000 BTW
Old May 27, 2013 | 03:35 PM
fmx23's Avatar
ANYBODY???
Old May 31, 2013 | 07:11 PM
2002Cummins's Avatar
Well, I had the cps go on one of my gas cars and it ran like garbage. Changed it and it was OK. I would think that maybe it would act the same on a diesel. Not sure though. Relatively inexpensive part.
MechanicalDiesel
Aug 11, 2015 08:14 PM
fivo2fst4u
Jul 2, 2015 06:20 PM
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
